Hot Topic (More than 10 Replies) Drag and drop (Read 10313 times)
binoo
Drag and drop
Dec 22nd, 2009 at 9:13am
I try to implement a drag and drop. I drag a node and drop it in a ListBox.
With the event MouseMove (or PreviewMouseMove) on the diagram like this :
    private void diagram_MouseMove(object sender, MouseEventArgs e) {
      Diagram diag = sender as Diagram;
      if (e.LeftButton == MouseButtonState.Pressed) {
        DiagramItem diagItem = this.diagram.GetItemAt(e.GetPosition(this), false);
I never pass in the if condition. It's normal ?
binoo
Re: Drag and drop
Reply #1 - Dec 22nd, 2009 at 9:40am
I try another solution too, with the event PreviewMouseMove of each node.
The method which create my node :
    private void CreateNode(object obj, ref ShapeNode node) {
      node.Text = obj.ToString();
      node.TextFormat.LineAlignment = StringAlignment.Center;
      node.Tag = obj;
      node.Shape = this.CreateShape(obj.ToString());
      node.Font.Size = 9.0;
      node.ToolTip = obj.ToString();
      node.Brush = Brushes.Transparent;
      node.Pen = new Pen(Brushes.Black, 1.0);
      node.PreviewMouseMove += new MouseEventHandler(node_MouseMove);
      #region Pour gérer le double clic sur un ShapeNode
      MouseGesture OpenCmdMouseGesture = new MouseGesture();
      OpenCmdMouseGesture.MouseAction = MouseAction.LeftDoubleClick;
      MouseBinding OpenCmdMouseBinding = new MouseBinding();
      OpenCmdMouseBinding.Gesture = OpenCmdMouseGesture;
      OpenCmdMouseBinding.Command = this.DoubleClickCommand;
      node.InputBindings.Add(OpenCmdMouseBinding);
      #endregion
      #region Pour gérer le simple click sur un ShapeNode
      OpenCmdMouseGesture.MouseAction = MouseAction.LeftClick;
      OpenCmdMouseBinding.Command = this.ClickCommand;
      #endregion
      node.AnchorPattern = new AnchorPattern(
        new AnchorPoint[] {
                new AnchorPoint(0, 50, true, false),
                new AnchorPoint(50, 100, false, true),
                new AnchorPoint(100, 50, false, true)
      // on ne veut pas voir les points d'accroches
      node.EnabledHandles = AdjustmentHandles.None;
      node.HandlesStyle = HandlesStyle.Invisible;
      // pour empécher le tracé de lien entre ShapeNode
      node.Locked = true;
As you can see, I add an InputBindings to the node for the MouseAction.LeftClick.
Without this InputBindings, all I have is the selection rectangle and the drag & drop don't work.
With this InputBindings, I can drag & drop in my ListBox, but the diagram don't understand that I succed my drag & drop when I come back over the diagram. Maybe due to the selection rectangle...
Undecided
Maybe this is not the good solution, so if you have got any sample.
Thanks.
Re: Drag and drop
Reply #2 - Dec 22nd, 2009 at 12:23pm
If you need to start drag-and-drop with the diagram as a source, try this:
void diagram_PreviewMouseMove(object sender, MouseEventArgs e)
		Point mp = e.GetPosition(diagram.DocumentPlane);
		var node = diagram.GetNodeAt(mp) as ShapeNode;
		if (node != null)
			e.Handled = true;
			DragDrop.DoDragDrop(diagram, node.Text, DragDropEffects.Copy);
			if (diagram.Interaction != null)
				diagram.Interaction.CancelNow();
binoo
Re: Drag and drop
Reply #3 - Dec 22nd, 2009 at 5:30pm
Thanks for your solution.
However, I've got a problem when I drop my node in my ListBox. When I drag one node, I've got two node in my ListBox.
Did you notice this problem ?
Re: Drag and drop
Reply #4 - Dec 23rd, 2009 at 8:26am
What does you listbox_DragDrop handler look like?
binoo
Re: Drag and drop
Reply #5 - Dec 23rd, 2009 at 9:23am
I've got this code :
    private void LboxToDropNode_DragOver(object sender, DragEventArgs e) {
      if (e.Data.GetDataPresent(typeof(string)))
        e.Effects = System.Windows.DragDropEffects.Copy;
      else
        e.Effects = System.Windows.DragDropEffects.None;
    private void LboxToDropNode_Drop(object sender, DragEventArgs e) {
      if (e.Data.GetDataPresent(typeof(string))) {
        // récupération de l'objet que l'on glisse
        string res = (string)e.Data.GetData(typeof(string));
        // utilisation de 'res'
        this.LboxToDropNode.Items.Add(res);
Re: Drag and drop
Reply #6 - Dec 23rd, 2009 at 10:09am
Is LboxToDropNode_Drop called twice after dropping the item?
Hunter
Re: Drag and drop
Reply #7 - Dec 23rd, 2009 at 1:57pm
Hi! I have the problem with drop. When I use in the NodeListView ShapeNode objects all works as need. But when I try to change the ShapeNode objects on the Custom objects and try to drop the object from the list to diagram I have an exception:
A first chance exception of type 'System.NullReferenceException' occurred in MindFusion.Diagramming.Wpf.dll
A first chance exception of type 'System.NullReferenceException' occurred in PresentationCore.dll
An unhandled exception of type 'System.NullReferenceException' occurred in PresentationCore.dll
Additional information: Object reference not set to an instance of an object.
    /// <summary>
    /// Class represents nodes which are using in the diagram with some additional
    /// properties
    /// </summary>
    public class CustomNode: ShapeNode
	  #region Data
	  NodeType m_nNodeType = NodeType.Bus;
	  int m_nInpNum = 0;
	  int m_nOutNum = 0;
	  #endregion //Data
	  #region Constructor
	  /// <summary>
	  /// Default constructor. Creates an empty object
	  /// </summary>
	  /// <param name="a_nNodeType">Sets the type of the node</param>
	  public CustomNode(NodeType a_nNodeType): base()
		m_nNodeType = a_nNodeType;
	  #endregion //Constructor
	  #region Properties
	  /// <value>
	  /// Gets type of the Node according to enum <see cref="NodeType"/>
	  /// </value>
	  public NodeType Type
	  { get { return m_nNodeType; } }
	  /// <value>
	  /// Gets or sets number of inputs of the node
	  /// </value>
	  public int InputNumber
		set { m_nInpNum = value; }
		get { return m_nInpNum; }
	  /// <value>
	  /// Gets or sets number of outputs of the node
	  /// </value>
	  public int OutputNumber
		set { m_nOutNum = value; }
		get { return m_nOutNum; }
	  #endregion //Properties
What's wrong?
Re: Drag and drop
Reply #8 - Dec 23rd, 2009 at 2:18pm
Implement either the Clone method or a copy constructor for your custom class.
Hunter
Re: Drag and drop
Reply #9 - Dec 23rd, 2009 at 2:53pm
Thank's. Now all is ok.
binoo
Re: Drag and drop
Reply #10 - Dec 24th, 2009 at 10:10am
Stoyo wrote on Dec 23rd, 2009 at 10:09am:
If I put a break point after :
With a break point, I have only one item which is added to my ListBox, without break point I have two items...
I notice another thing. When I change the DragOver code like this :
	else
I change the DragDropEffects.Copy in DragDropEffects.None, I have only one item added in my ListBox. But the user don't know that he can drop here...
I send a sample project to your profil email adress.
Thank you.
Re: Drag and drop
Reply #11 - Dec 24th, 2009 at 10:58am
From the call stack shown when a breakpoint is hit, I suppose WPF manages to send us a second PreviewMouseMove message during the execution of the DragDrop method because the diagram has acquired the mouse capture. It seems if you release it, it works as expected:
     diagram.ReleaseMouseCapture();
binoo
Re: Drag and drop
Reply #12 - Jan 4th, 2010 at 1:29pm
Thank you ! Smiley
