Normal Topic Diagram in tree layout (Read 3377 times)
vishnupriya
Dec 23rd, 2009 at 9:30am
I am able to create the diagram in a tree layout. But the problem in my application is , the links are setting in "LeftInRightOut" . But I want to make it "TopInBottomOut".  I am using below line for the same.
node.AnchorPattern = AnchorPattern.TopInBottomOut;
But it is not working.
Can some one please le tme know how I can chagne the links, that will start at parent bottom center and ends with the child top center.
Thanks in advance ,
Vishnupriya
Re: Diagram in tree layout
Reply #1 - Dec 23rd, 2009 at 10:11am
Setting AnchorPattern does not automatically update existing links. You might try running TreeLayout again with its Anchoring property set to Reassign.
vishnupriya
Reply #2 - Dec 23rd, 2009 at 10:42am
Thanks Stoyan for the information.
I have tried out with the below code.
tl.Anchoring = Anchoring.Reassign;
           tl.Arrange(diagram1);
But this also not working. As I am new to this ,Can you please give me some more information.
Thanks & Regards,
Vishnupriya
Reply #3 - Dec 23rd, 2009 at 12:18pm
Have you set AnchorPattern to TopInBottomOut for all nodes before running the layout?
vishnupriya
Reply #4 - Dec 23rd, 2009 at 12:41pm
Hi, I am using the below code.
private void CreateDiagram()
diagram1.LinkCascadeOrientation = MindFusion.Diagramming.Orientation.Vertical;
diagram1.LinkStyle = LinkStyle.Bezier;
diagram1.LinkHeadShape = ArrowHead.BowArrow;
diagram1.LinkHeadShapeSize = 3;
diagram1.ShowAnchors = ShowAnchors.Always;
TableNode rootNode = new TableNode(diagram1);
MindFusion.Drawing.SolidBrush oBrush = new MindFusion.Drawing.SolidBrush(Color.LightGreen);
rootNode.Caption = "Brand(12)";
rootNode.Style = TableStyle.RoundedRectangle;
rootNode.ColumnCount = 3;
rootNode.Columns[0].Width = 25;
rootNode.Columns[1].Width = 13;
rootNode.Columns[2].Width = 12;
rootNode.RowCount = 2;
rootNode[0, 0].Text = "Sales $(M)";
rootNode[0, 1].Text = "Sales $ MAT (M)";
rootNode[1, 0].Text = "12345";
rootNode.Brush = oBrush;
rootNode.Bounds = new RectangleF(50, 15, 50, 20);
rootNode.Tag = 0;
diagram1.Nodes.Add(rootNode);
TableNode curNode = new TableNode(diagram1);
foreach (TreeNode node in trvAttributes.Nodes[0].Nodes)
curNode = addChild(rootNode, node, diagram1, oBrush);
foreach (TreeNode secNode in trvAttributes.Nodes[1].Nodes)
addChild(curNode, secNode, diagram1, oBrush);
if (tl == null)
tl = new TreeLayout(rootNode,
TreeLayoutType.Centered,
false,
TreeLayoutLinkType.Rounded,
TreeLayoutDirection.TopToBottom,
10, 5, true, new SizeF(10, 10));
diagram1.ResizeToFitItems(5, true);
private TableNode addChild(TableNode rootNode, TreeNode attrNode, Diagram cdgrm, MindFusion.Drawing.SolidBrush brush)
TableNode childNode = new TableNode(cdgrm);
if (intLnk == 0)
intLnk = 1;
childNode.Bounds = new RectangleF(0, (rootNode.Bounds.Y + 100), 50, 20);
else
intLnk = 0;
childNode.Caption = "Brand : " + attrNode.Text + "(3)";
childNode.Style = TableStyle.RoundedRectangle;
childNode.ColumnCount = 3;
childNode.RowCount = 3;
childNode.Brush = brush;
childNode.Columns[0].Width = 25;
childNode.Columns[1].Width = 13;
childNode.Columns[2].Width = 12;
childNode[0, 0].Text = "Sales $(M)";
childNode[0, 1].Text = "Sales $ MAT (M)";
childNode.AttachTo(rootNode, AttachToNode.BottomLeft);
cdgrm.Nodes.Add(childNode);
DiagramLink link = new DiagramLink(cdgrm, rootNode, childNode);
rootNode.AnchorPattern = AnchorPattern.TopInBottomOut;
childNode.AnchorPattern = AnchorPattern.TopInBottomOut;
link.SnapToNodeBorder = false;
cdgrm.Links.Add(link);
return childNode;
Can you please let me know the way to do..?
Vishnupriya
Reply #5 - Dec 23rd, 2009 at 1:12pm
Try setting the tables' ConnectionStyle property = Table, otherwise the links might be connecting to the tables rows and ignoring the nodes' AnchorPattern (rows have their own AnchorPattern property).
vishnupriya
Reply #6 - Dec 23rd, 2009 at 1:19pm
Thank you very much Stoyan.
It worked.
Thanks & Regards,
Vishnupriya
