Normal Topic How to use the item's reminder (Read 7113 times)
gerardo
Jan 5th, 2010 at 10:04pm
I'm trying to use the reminder in my calendar but it seems that I'm missing something. This is the code that I'm working with (it should display the message 5 minutes prior to the item's Start Time), but is not working:
                           app.Reminder = New Reminder()
                           app.Reminder.TimeInterval = New System.TimeSpan(0, 5, 0)
                           app.Reminder.Type = ReminderType.Leading
                           app.Reminder.Message = "Test - " + app.HeaderText + " " + app.DescriptionText
Re: How to use the item's reminder
Reply #1 - Jan 6th, 2010 at 9:37am
The reminder messages are not displayed automatically. You need to handle the ItemReminderTriggered event of the Schedule class and perform the necessary actions (such as displaying a message box) there.
void Schedule_ItemReminderTriggered(object sender, MindFusion.Scheduling.ItemEventArgs e)
      MessageBox.Show(e.Item.Reminder.Message);
Let me know if this works.
gerardo
Reply #2 - Jan 6th, 2010 at 4:14pm
I'm working with the class Calendar, so I don't have access to the event: ItemReminderTriggered
that I can see is available for the Schedule class.
However I was able to catch the event using an auxiliar object schedule like this:
MySchedule as Schedule
MySchedule = MyCalendar.Schedule
then I assigned a handler like:
AddHandler MySchedule .ItemReminderTriggered, AddressOf Schedule_ItemReminderTriggered
So far, this is working for me, but any suggestions are welcome.
Reply #3 - Jan 6th, 2010 at 6:10pm
You can use the AddHandler command to attach a handler method to the schedule's event without creating additional variables.
gerardo
Reply #4 - Jan 6th, 2010 at 9:54pm
I changed it and now is working with the original object.  Smiley
Thanks.
