Normal Topic Issues with Overview Window (Read 3802 times)
Anshul
Senior Member
Jan 6th, 2010 at 10:17am
Hi Stoyan,
We are getting two issues with Overview Window.
1). When FitAll = true, everything works fine but if we set FitAll = false and scroll mouse over the window, Zooming operation is performed over the window. Is there any way to restrict zooming when FitAll = false?
2). We want to change overview window's Gray color. How can we do this?
Please suggest.
Anshul
Re: Issues with Overview Window
Reply #1 - Jan 6th, 2010 at 2:21pm
Hi Anshul,
1. Handle Overview.PreviewMouseWheel and set e.Handled = true;
2. Set ovw.DimBrush = Brushes.Transparent;
Anshul
Senior Member
Reply #2 - Jan 7th, 2010 at 6:10am
Thanks Stoyan,
Both issues have been solved.
We have one more issue. Overview window size is increasing /decreasing with respect to diagram size. Can we make it fixed size (irrespective of diagram size)?
Anshul
Reply #3 - Jan 7th, 2010 at 8:42am
The overview's Measure override returns the diagram size multiplied by the overview's scale. I think WPF should honor your preferred size if you set fixed overview.Width and Height values.
Anshul
Senior Member
Reply #4 - Jan 8th, 2010 at 1:34pm
Hi Stoyan,
We will try this out.
We had reported an issue regarding "scroll mouse over the window, Zooming operation is performed" and you had provided solution for this like
This has solved our issue but we want to stop only zooming not scrolling. Now I am not able to scroll over the overview window.
Please suggest for this.
Anshul
Reply #5 - Jan 8th, 2010 at 1:52pm
Hi Anshul,
You could call scrollviewer.ScrollToVerticalOffset(scrollviewer.VerticalOffset + e.Delta) to scroll from that handler.
Anshul
Senior Member
Reply #6 - Jan 19th, 2010 at 8:25am
Hi Stoyan,
I have tried this but by this scrolling is working for diagram not for overview window.
When my mouse is over the OverviewWindow and I try to scroll, scroll viewer of diagram get scroll. I want OverviewWindow's scroll bar to work.
Anshul
Anshul
Senior Member
Reply #7 - Jan 22nd, 2010 at 12:21pm
Hi Stoyan,
Any update on this?
Reply #8 - Jan 22nd, 2010 at 1:14pm
Hi Anshul,
Set
var scrollviewer = overview.Content as ScrollViewer;
before calling
scrollviewer.ScrollToVerticalOffset(...);
