Normal Topic Operation node: overlayNode (Read 2499 times)
D
Apr 6th, 2020 at 8:28am
Drag the edge or diagonal of overlayNode to change the size of overlayNode. How to achieve this?
Lyubo
MindFusion team
Re: Operation node: overlayNode
Reply #1 - Apr 6th, 2020 at 10:04am
To enable interactions on nodes make sure the ShapeNode.Locked property is set to false and the setting of Diagram.Behavior permits interactions with the items - i.e. it's not set to Pan or DoNothing.
You will probably need to invalidate the visuals of the background node from the overlay nodes NodeModfied handler to update the transparency layer.
Lyubo
MindFusion
D
Reply #2 - Apr 6th, 2020 at 11:01am
Thank you very much for your answer, Lyubo.
Do you say "please make sure the ShapeNode.Locked property is set to false" refers to setting imageNode.Locked and overlayNode.Locked to false? Also, I do n’t quite understand what you said about “The visual effect of covering the background node in NodeModfied handler is invalid to update the transparent layer”. Is there any sample code?
cs:
        private void ImageManipulation(string path)
var myImage = new BitmapImage(new Uri(path, UriKind.Relative));
var imageWidthPx = myImage.PixelWidth * GetScreenDpi() / myImage.DpiX;
var imageHeightPx = myImage.PixelHeight * GetScreenDpi() / myImage.DpiY;
var imageWidth = GraphicsUnit.Pixel.Convert(imageWidthPx, diagram.MeasureUnit);
var imageHeight = GraphicsUnit.Pixel.Convert(imageHeightPx, diagram.MeasureUnit);
imageNode = diagram.Factory.CreateShapeNode(0, 0, imageWidth, imageHeight);
imageNode.Image = myImage;
imageNode.Shape = Shapes.Rectangle;
imageNode.CustomDraw = CustomDraw.Additional;
imageNode.ImageAlign = ImageAlign.Fit;
//overlayNode = diagram.Factory.CreateShapeNode(0, 0, 150, 150);
var overlayNodeWidth = 100;
var overlayNodeHeight = 100;
overlayNode = diagram.Factory.CreateShapeNode(imageNode.Bounds.Right - overlayNodeWidth,
imageNode.Bounds.Bottom - overlayNodeHeight, overlayNodeWidth, overlayNodeHeight);
overlayNode.Shape = Shapes.Rectangle;
overlayNode.Brush = Brushes.Transparent;
overlayNode.StrokeThickness = 0.8;
overlayNode.Stroke = new SolidColorBrush(Color.FromArgb(120, 12, 236, 13));
overlayNode.Locked = true;
overlayNode.AttachTo(imageNode, AttachToNode.BottomRight);
Lyubo
MindFusion team
Reply #3 - Apr 6th, 2020 at 11:42am
The Locked property of the node that you wish to interact with.
D wrote on Apr 6th, 2020 at 11:01am:
Haven't said that anywhere. What I said is to make sure the transparent layer is invalidated for redrawing after you've interacted with the node. And as it stands in your example, that can be achieved by calling imageNode.InvalidateVisual(); from a overlayNode's NodeModifed event handler.
Lyubo
MindFusion
D
Reply #4 - Apr 6th, 2020 at 1:31pm
Thank you so much, Lyubo. Smiley I know that my code is definitely wrong, please guide me to correct it and
how to add NodeModifed event handler for overlayNode.
