Normal Topic Dragging nodes inside the diagram (Read 3698 times)
Hunter
Jan 11th, 2010 at 12:22pm
I implemented 2 event handlers:
	  private void OnDiagram_NodeModifying(object sender, NodeValidationEventArgs e)
		if (e.Node.Bounds.Top < 1 || e.Node.Bounds.Left < 1)
		    e.Cancel = true;
		foreach(DiagramLink link in e.Node.GetAllLinks())
		    if (link.ControlPoints.Count == 3)//Linear link
			  link.Route();
	  private void OnDiagram_SelectionMoving(object sender, ValidationEventArgs e)
		Selection selection = m_Diagram.Selection;
		if (selection.Bounds.Top < 1 || selection.Bounds.Left < 1)
		    e.Cancel = true;
Is there any way to stop dragging selection or node instead e.Cancel = true;
CancelDrag() is bad for me because it returns the old position and I want to stop dragging at current position (Top or Left == 1)?
Re: Dragging nodes inside the diagram
Reply #1 - Jan 11th, 2010 at 1:28pm
Diagram.Interaction.Complete() should do that. However I'm not sure if a validation event would be a nice place for calling it; if it doesn't work from these handlers, try calling it from the behavior class' OnMouseMove override.
Hunter
Reply #2 - Jan 14th, 2010 at 7:52am
Hello, Stoyan! Say me please how can I override the event Ctrl+MouseDrag? I want to implement the following behavior: when user presses the Ctrl key and drag the node by mouse this node will be copied at the drop mouse position
Reply #3 - Jan 14th, 2010 at 8:44am
Set diagram.ModifierKeyActions.Control = None to stop drawing a selection rectangle when Ctrl is pressed. In the StartDraw override check if Keyboard.Modifiers & Control is set, and if so clone the underlying node and return InteractionState(clone, Modify).
Hunter
Reply #4 - Jan 14th, 2010 at 9:33am
Thanks! All works ok!
Amx
digito ergo sum
Reply #5 - Jan 19th, 2010 at 3:47pm
Hi, I'm testing Diagramming for WPF to replace our current diagramming lib.
I need to drag a node with the same simplicity used to add a link (by clicking only one time a node, without select it before) but I don't find the way... Cry
Best regards,
Amx.
Reply #6 - Jan 19th, 2010 at 3:52pm
Set Diagram.ModificationStart = Auto.
Best regards,
Amx
digito ergo sum
Reply #7 - Jan 19th, 2010 at 4:03pm
Great.. Tnx Wink
