Normal Topic SVG / PDF Exporters memory usage (Read 1612 times)
MikeB
May 7th, 2024 at 12:41pm
I have do more tests with svg exporter (the same problem is for pdf exporter) trying to export more complicated diagrams and i have observed an memory ussage issue.
With each call diagram_DoubleClicked the memory usage increases and after the finished export operation memory is not being freed.
Code (C++)
    public partial class MainWindow : Window
        public List<Diagram> diagrams { get; set; }
        public MainWindow()
            InitializeComponent();
            var rand = new Random();
            diagrams = new List<Diagram>();
            for (int j = 0; j < 40; j++)
                var diag = new Diagram();
                for (int i = 0; i < 100; i++)
                    var shapeNode = new ShapeNode()
                        Shape = new Shape(new ElementTemplate[]
                            new LineTemplate(0, 0, 100, 0),
                            new LineTemplate(100, 0, 100, 100),
                            new LineTemplate(100, 100, 0, 100),
                        }, FillRule.EvenOdd),
                    shapeNode.AddLabel(new NodeLabel() { Text = "Test" });
                    diag.Nodes.Add(shapeNode);
                    diag.Nodes.Last().Move(rand.Next(0, 1000), rand.Next(0, 1000));
                diagrams.Add(diag);
        private void diagram_DoubleClicked(object sender, DiagramEventArgs e)
            var exporter = new PdfExporter();
            foreach (var diag in diagrams)
                exporter.Export(diag, @"D:\temp\diagram.svg");
Re: SVG / PDF Exporters memory usage
Reply #1 - May 8th, 2024 at 11:39am
This build fixes exporter leaks -
https://mindfusion.eu/_temp/wpfdiag_expmem.zip
First export still allocates a lot of memory because ShapeNodes cache their geometries when first drawn. Subsequent exports should stay stable.
MikeB
Reply #2 - May 8th, 2024 at 11:56am
It's better.... but not perfect.
Why memory allocated to ShapeNodes cache is not being freed after saving the output file ?
Reply #3 - May 8th, 2024 at 12:15pm
That cache is not specific to PDF exporter and should be reused both for on-screen rendering and different exports. After second export you can only see some WeakReferences added between heap snapshots, which .NET should free when it needs the memory. So that's as close to perfect as possible according to our developer Smiley
Reply #4 - May 8th, 2024 at 12:17pm
If you really need to free that memory after full rendering of offscreen diagrams, you could try exporting their copies instead, or after export clear each diagram and reload from a file or your data. Otherwise you'll have the window -> diagrams array -> nodes -> cached geometries references from root preventing GC from reclaiming the added cache.
MikeB
Reply #5 - May 8th, 2024 at 6:24pm
Slavcho wrote on May 8th, 2024 at 12:15pm:
Look at my example..... i don't need the List<Diagram> on screen rendering. I want to export the list to PDF. The exporter should allocate memory needed to render diagrams, produce output file and free the cache and memory that needed to do his work.
« Last Edit: May 9th, 2024 at 6:00am by MikeB »
Reply #6 - May 9th, 2024 at 7:58am
Maybe it should, but we've been developing this as UI control that has one or two on-screen instances, that users might occasionally export to PDF. Most of the WeakReferences that grow the heap are WPF internals anyway from what we can tell, and .NET will recycle them when memory needed.
If you are looking to create a PDF generation service for large number of off-screen diagrams with lower memory footprint, you could try the diagramming.dll from our ASP.NET and WinForms controls (it's shared between them); this same test never takes more than 50MB with it -
public partial class Form1 : Form
	public Form1()
					}, System.Drawing.Drawing2D.FillMode.Alternate),
			diag.ResizeToFitItems(5);
			diagrams.Add(diag);
	private void button1_Click(object sender, EventArgs e)
			exporter.Export(diag, "diagram.pdf");
https://www.nuget.org/packages/MindFusion.Diagramming/
« Last Edit: May 9th, 2024 at 10:33am by Slavcho »
