Normal Topic SVG Exporter label issue (Read 239 times)
MikeB
May 7th, 2024 at 10:20am
I,ve got exception if i use SVG Exporter for Nodes that has the label containing character "-".
Code (C++)
public MainWindow()
    InitializeComponent();
    var shapeNode = new ShapeNode()
        Shape = new Shape(new ElementTemplate[]
            new LineTemplate(0, 0, 100, 0),
            new LineTemplate(100, 0, 100, 100),
            new LineTemplate(100, 100, 0, 100),
        }, FillRule.EvenOdd),
    shapeNode.AddLabel(new NodeLabel() { Text = "Label - 1" });
    diagram.Nodes.Add(shapeNode);
    diagram.Nodes.First().Move(50, 50);
private void diagram_DoubleClicked(object sender, DiagramEventArgs e)
    SvgExporter svgExporter = new SvgExporter();
    svgExporter.Export(diagram, @"D:\temp\diagram.svg");
Re: SVG Exporter label issue
Reply #1 - May 7th, 2024 at 5:53pm
This build should fix the exception -
https://mindfusion.eu/_temp/wpfdiag_svgex.zip
MikeB
Reply #2 - May 8th, 2024 at 7:33am
Thanks, now it works perfectly Grin
