Normal Topic RestrictToBounds (Read 1306 times)
danmeland
RestrictToBounds
Jan 13th, 2010 at 5:03pm
Ok, I know someone has brought this up b4, but...
How do I restrict, in SilverLight, the movement of a controlnode from leaving the bounds of the grid layout diagram?
Cant find an answer easily.  THanks
Re: RestrictToBounds
Reply #1 - Jan 13th, 2010 at 5:41pm
I think there's such property in our controls for other platforms, but it's not available for Silverlight. You can achieve the same effect by handling the NodeModifying event and setting e.Cancel = true if the diagram.Bounds rectangle does not contain e.Node.Bounds.
