Normal Topic Override command bindings (Read 1663 times)
Hunter
Jan 18th, 2010 at 1:32pm
Hello, Stoyan. I have a small question. How can I override the Ctrl+C(Ctrl+Insert) and Ctrl+V(Shift+Insert) modifiers?
I create a command such as
		inputs = new InputGestureCollection();
		inputs.Add(keyGesture);
		keyGesture = new KeyGesture(Key.Insert, ModifierKeys.Control, "Ctrl+Insert");
		m_CmdCopy = new RoutedUICommand("Копировать", "Copy",
		    typeof(MenuCommands), inputs);
All works ok. But I don't go to my event handler for this command. And when I call the command from menu I can stay in the body of my event handler. I suppose that key gestures works because some default command bindings are present
Re: Override command bindings
Reply #1 - Jan 18th, 2010 at 3:37pm
Hi there,
The control registers some class-level bindings for the Copy/Cut/Paste ApplicationCommands. You can override them by adding your own binding to an instance of the diagram as shown in this post:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=123871818...
Hunter
Reply #2 - Jan 18th, 2010 at 3:48pm
Thank you very much
