Normal Topic weeks don't start with saturday here (Read 4159 times)
springy
Jan 25th, 2010 at 9:19am
Where can I change this to Monday?
(I'm aware of rumors that somewhere in the world weeks start with sunday -- but saturday??)
/\/\arkus.
Re: weeks don't start with saturday here
Reply #1 - Jan 25th, 2010 at 9:47am
Try the following code (assuming that your Calendar is identified by the variable cal):
cal.BeginInit();
cal.DateTimeFormat.FirstDayOfWeek = DayOfWeek.Monday;
cal.EndInit();
The BeginInit/EndInit block is essential because changing properties of the DateTimeFormat alone does not cause updates.
springy
Reply #2 - Jan 25th, 2010 at 10:10am
Thanks, didn't notice this property hierarchy.
But could you please remove the FirstDayOfWeek=DayOfWeek.Saturday somewhere in your code?
Because cal.DateTimeFormat.DayNames, ~MonthNames etc. are all German but .FirstDayOfWeek is still Saturday.
In contrast CultureInfo.CurrentCulture.DateTimeFormat also contains the German DayNames (and so forth) but FirstDayOfWeek correctly is set to Monday.
/\/\arkus.
Reply #3 - Jan 25th, 2010 at 10:47am
