Normal Topic Anchor Point changing style after connecting (Read 1912 times)
solisgsandc
Feb 11th, 2010 at 4:57pm
Is there a property that I can set on the ShapeNode to have the anchor point change style from an X to a O ( circle ) when that particular anchor point is connected to a link?
Re: Anchor Point changing style after connecting
Reply #1 - Feb 11th, 2010 at 7:14pm
There isn't. Try setting the point's MarkStyle to Custom and drawing the X/O in response to the DrawAnchorPoint event depending on whether there is a link connected to the point. In such case you might also have to call the node's Repaint method when a new link is connected to it.
solisgsandc
Reply #2 - Feb 11th, 2010 at 7:50pm
Can you please send a sample code if possible?
Reply #3 - Feb 14th, 2010 at 10:50am
This seems to work:
private void OnLinkCreated(object sender, LinkEventArgs e)
	UpdateAnchorPoints(e.Link.Origin);
	UpdateAnchorPoints(e.Link.Destination);
private void OnLinkModified(object sender, LinkEventArgs e)
private void UpdateAnchorPoints(DiagramNode node)
	if (node.AnchorPattern == null)
		return;
	var usedPoints = new Dictionary<int, bool>();
	foreach (DiagramLink link in node.IncomingLinks)
		if (link.DestinationAnchor >= 0)
			usedPoints[link.DestinationAnchor] = true;
	foreach (DiagramLink link in node.OutgoingLinks)
		if (link.OriginAnchor >= 0)
			usedPoints[link.OriginAnchor] = true;
	for (int i = 0; i < node.AnchorPattern.Points.Count; ++i)
		AnchorPoint ap = node.AnchorPattern.Points[i];
		ap.MarkStyle = usedPoints.ContainsKey(i) ? MarkStyle.Circle : MarkStyle.X;
		ap.InvalidateVisual();
