Normal Topic Attaching a notification icon to a shapeNode (Read 1846 times)
solisgsandc
Feb 11th, 2010 at 4:59pm
Is there a property that I can set on the shapeNode to have an icon associated with it?
Re: Attaching a notification icon to a shapeNode
Reply #1 - Feb 11th, 2010 at 7:19pm
Yes, set the node's Image property.
solisgsandc
Reply #2 - Feb 11th, 2010 at 7:49pm
If the node uses an image already then my other solution would be to attach an icon image to the node. Is this the next best thing?
Reply #3 - Feb 11th, 2010 at 9:50pm
This will work, but a more lightweight solution is to set node.CustomDraw = Additional and call e.Graphics.DrawImage(icon) from the DrawNode handler. Or if you are using a derived class, override the node class Draw method to do the same.
