Normal Topic AllowOutgoingLinks with HandlesStyle.EasyMove (Read 1477 times)
fireboy
Mar 8th, 2010 at 1:34pm
it looks like AllowOutgoingLinks property on a ShapeNode is ignored when the node has HandlesStyle set to EasyMove. It's possible to draw links from the bubble in the center.
How can I prevent creation of links from a node with EasyMove handles?
Re: AllowOutgoingLinks with HandlesStyle.EasyMove
Reply #1 - Mar 8th, 2010 at 2:43pm
Try this as a work-around:
private void OnLinkCreating(object sender, LinkValidationEventArgs e)
	if (!e.Origin.AllowOutgoingLinks)
		e.CancelDrag();
fireboy
Reply #2 - Mar 8th, 2010 at 3:01pm
Thanks, it works.
