Normal Topic Link destination treeviewitem on the TreeViewNode. (Read 2003 times)
DKHMM
Mar 8th, 2010 at 1:55pm
Hi
I have a TableNode and a TreeViewNode, when I create a link between the tablenode (Origin) and the TreeViewNode (Destination)
I have difficuties getting the destination treeviewitem on the TreeViewNode.
The origin can be found (line 5)
But I cannot get the TreeViewItem the same way, please let me know how to get this.
private void LinkCreatedEvent(object sender, LinkEventArgs e)
TableNode originTableNode = e.Link.Origin as TableNode;
TreeViewNode targetTreeViewNode = e.Link.Destination as TreeViewNode;
var OriginFieldName = originTableNode[1, e.Link.OriginIndex].Text;
var targetFieldName = ????
Re: Link destination treeviewitem on the TreeViewN
Reply #1 - Mar 8th, 2010 at 3:08pm
Try using the following method for now:
var treeNode = e.Link.Destination as TreeViewNode;
var endPoint = e.Link.ControlPoints[e.Link.ControlPoints.Count - 1];
Debug.WriteLine(treeNode.ItemFromPoint(endPoint, true).Label);
We'll implement a more consistent way to get the item in the version we are currently releasing.
DKHMM
Reply #2 - Mar 8th, 2010 at 3:14pm
Thanks for your quick reply.
It works for now !
Best Regards
Henrik
