Normal Topic Issue with Overview Window's Width (Read 1855 times)
Anshul
Senior Member
Mar 14th, 2010 at 12:10pm
We are having thousands of nodes arranged in 2 columns in our diagram. We are using overview window for this diagram.
We are setting Overview window's height is equal to its container's client area but when nodes rendered in the digram, overview window's width get decresed. We want it should cover entire client area.
Please suggest what we are missing?
We are sending screenshot of our overview window at your support ID, please have a look at that also.
Anshul
Re: Issue with Overview Window's Width
Reply #1 - Mar 16th, 2010 at 9:02am
If you are using FitAll mode, the overview displays the diagram.Bounds rectangle scaled to fit the overview client area. We could add some property to let you set the overview background to the diagram background so that the whole window is filled. However you would still be able to scroll only within the diagram.Bounds area.
Reply #2 - Mar 16th, 2010 at 11:32am
Or do you expect something like fit-width mode in this case?
