Normal Topic Node Proximity-Based Link Behaviour (Read 2338 times)
Paul Eden
Feb 23rd, 2010 at 11:13am
hi
Is there a property that would act as a threashold that effects where the diagram will connect Links to Nodes?
We are seeing that when nodes are particularly close, the Link end-points will jump to the center of the node (normally in conjunction with UIElements rather than ShapeNodes).  Moving the nodes apart, the link will jump back to the outer edge of the node.  Is there a way to reduce the distance at which this occurrs or (possibly, preffered) prevent this happening completely?
Many thanks
Paul
Re: Node Proximity-Based Link Behaviour
Reply #1 - Feb 23rd, 2010 at 11:35am
This should happen only if the nodes intersect. For hosted controls, the control enumerates the constituent visuals of the 2 UIElement to determine if any of them intersects. If this does not work for the kind of controls you are using, we could add some callback to let your determine if the nodes intersect, or some property to make links connect to the node borders in all cases.
Paul Eden
Reply #2 - Feb 23rd, 2010 at 12:05pm
In our current usage the simplest option would suit us fine, where the Links snap to the Node border regardless, though I dare say some other users would like to have fine control over how things act.
Paul
Reply #3 - Mar 16th, 2010 at 8:18am
Please check it this will work for you:
https://mindfusion.eu/_beta/wpfdiag231.zip
If nodes intersect, the link end will be placed at the nearest point of the node border instead of the node's center. It's kind of using the SnapToBorder behavior as a fallback.
