Normal Topic Creating Diagram Object? (Read 1164 times)
Bander
Mar 14th, 2010 at 10:46pm
Each time I run my application in debug mode in Visual Studio a Diagram object is created. i.e.  1st time I run it crates Diagram2, 2nd time Diagram3, etc.
Anyone have a clue on this?  I can delete the extra created one and the app compiles correctly, but this is very annoying to have to cleanup every time I test out a new section of code.
Re: Creating Diagram Object?
Reply #1 - Mar 15th, 2010 at 8:36am
This might happen if Visual Studio uses cached diagramming.dll and diagramming.winforms.dll from different versions of the control. Try deleting the MindFusion.* assemblies from the following folders, while VS is not running:
C:\Documents and Settings\***\Local Settings\Application Data\Microsoft\Visualstudio\8.0\Projectassemblies
C:\Documents and Settings\***\Local Settings\Application Data\assembly\
Replace *** with your account name.
