Normal Topic Anchor points (Read 2947 times)
fireboy
Anchor points
Mar 16th, 2010 at 4:20pm
Some more problems/questions:
1. Anchor points are always shown in NodeListView. I think it would be better to hide them in NodeListView and show them on the Diagram.
2. When Diagram.ShowAnchors is set to Auto, anchors appear when mouse approaches the anchor point from the right and from the bottom, but not from the left or from the top. This makes it very awkward to connect links to anchor points located on the top and left sides of a shape. I think that absolute distance from the mouse to the anchor point should be checked.
3. Is it possible to make anchor marks smaller or change their color? I can subclass a shape or a diagram if that's necessary.
Thanks.
Re: Anchor points
Reply #1 - Mar 16th, 2010 at 6:27pm
2. I can't reproduce this, could you send a sample project showing it to support@mindfusion.eu?
3. The AnchorPoint class has Brush and Size properties.
fireboy
Re: Anchor points
Reply #2 - Mar 17th, 2010 at 10:08am
I hope that this picture illustrates the problem:
Basically, the behavior is not symmetrical. The anchors appear early when the mouse pointer is approaching the shape from the right and from the bottom. But the mouse pointer has to be quite deep (!) inside the shape for the anchors to appear when it is approaching from the left and from the top.
Any ideas?
Re: Anchor points
Reply #3 - Mar 17th, 2010 at 2:28pm
It does illustrate the problem, but we can't reproduce it. Are you using standard ShapeNodes with Shape.Ellipse? Could you send us a test project, or copy the diagram and node initialization code here?
fireboy
Re: Anchor points
Reply #4 - Mar 17th, 2010 at 3:17pm
Yes, I can reproduce the problem with standard Ellipse.
ShapeNode node = new ShapeNode();
            node.Shape = Shapes.Ellipse;
            node.AnchorPattern = new AnchorPattern(new AnchorPoint[] {
                new AnchorPoint(50, 0),
                new AnchorPoint(50, 100),
                new AnchorPoint(0, 50),
                new AnchorPoint(100, 50)});
            workflowDiagram.Nodes.Add(node);
Diagram definition in XAML:
<my:Diagram Width="Auto" Height="Auto" AllowInplaceEdit="False" Name="workflowDiagram" ShowGrid="True" AlignToGrid="True" LinkCreating="workflowDiagram_LinkCreating" RouteLinks="True" GridStyle="Lines" GridColor="#1B000000" GridPointSize="1" GridSizeY="10" GridSizeX="10" LinkCrossings="Arcs" LinkStyle="Cascading" UndoEnabled="True" ItemAdded="workflowDiagram_ItemAdded" AdjustmentHandlesSize="8" KeyDown="workflowDiagram_KeyDown" SelectionChanged="workflowDiagram_SelectionChanged" NodeDoubleClicked="workflowDiagram_NodeDoubleClicked" NodeModified="workflowDiagram_NodeModified"  />
Re: Anchor points
Reply #5 - Mar 17th, 2010 at 8:10pm
This also works fine for me. Could you post the workflowDiagram_ItemAdded code too?
