Normal Topic Diagram rendering performance issue for nodes (Read 4990 times)
Bala
Mar 19th, 2010 at 9:54am
We need to show two columns with 1024 nodes in each column. and need to show shadow for shape nodes but not for the attached label node. It is taking around 18 seconds. We need to improve this performance.
Let know how we can improve this performance. Is there any way that we can use separate thread or background worker to improve the performance.
It will really be helpful if you provide sample code for this.
We have sent a sample project regarding this issue at your support ID. Please have a look into that.
Bala
Re: Diagram rendering performance issue for nodes
Reply #1 - Mar 19th, 2010 at 12:10pm
It takes 5-6 seconds with the following modifications:
var now = DateTime.Now;
diagram.ValidityChecks = false;
diagram.BeginInit();
for (int i = 0; i <= 1024; i++)
	ShapeNode srcNode = createNode(new Rect(100, 100 + i * 40, nodeWidth, nodeHeight));
	ShapeNode snkNode = createNode(new Rect(400, 100 + i * 40, nodeWidth, nodeHeight));
	DiagramLink link1 = new DiagramLink(diagram, srcNode, snkNode);
	diagram.Links.Add(link1);
diagram.EndInit();
diagram.LinkCrossings = LinkCrossings.Cut;
Debug.WriteLine(DateTime.Now - now);
where diagram.LinkCrossings is moved from InitDiagram. And the createNode method is refactored to use shared BitmapImage and ShadowEffect objects:
BitmapImage encoderImage = new BitmapImage(
	new Uri(@"..\..\Encoder.png", UriKind.RelativeOrAbsolute));
Color shadowColor = new Color { ScA = 1, ScB = 0, ScG = 0, ScR = 0 };
DropShadowEffect dropShadow = new DropShadowEffect {
	RenderingBias = RenderingBias.Performance, ShadowDepth = 8 };
private ShapeNode createNode(Rect rect)
	var mainNode = new ShapeNode { Bounds = rect };
	diagram.Nodes.Add(mainNode);
	mainNode.Image = encoderImage;
	var lr = new Rect(mainNode.Bounds.X - mainNode.Bounds.Width, mainNode.Bounds.Y,
		mainNode.Bounds.Width, mainNode.Bounds.Height);
	var lableNode = new ShapeNode { Bounds = lr };
	diagram.Nodes.Add(lableNode);
	lableNode.AttachTo(mainNode, AttachToNode.MiddleLeft);
	mainNode.Effect = dropShadow;
	return mainNode;
There was an unnecessary Nodes.Add(mainNode) at the end of the method, now remove. Watch out for adding items two times, especially with ValidityChecks disabled.
Bala
Reply #2 - Mar 23rd, 2010 at 3:02pm
Thanks for the code snippet, it improves the performance.
We are having a little issue with this code.
After implementing the suggested changes, the attached label node text are now displaying too far from the main node for the left column.
Earlier the label node text was displayed properly.
We have reproduced this issue in the sample. We are sending the sample, please suggest.
Bala
Reply #3 - Mar 23rd, 2010 at 3:45pm
Try replacing these lines
lableNode.TextFormat.Alignment = StringAlignment.Far;
lableNode.TextFormat.LineAlignment = StringAlignment.Far;
lableNode.TextFormat.FormatFlags = StringFormatFlags.DirectionRightToLeft;
with
lableNode.TextFormat = new StringFormat
	Alignment = StringAlignment.Far,
You should assign a new object, because otherwise the nodes share a common StringFormat instance as default, which is later changed to left-aligned for the second column. This worked before because the ShapeNode(Diagram) constructor clones the format object, however we replaced it with a no-args constructor, which works faster.
Bala
Reply #4 - Mar 24th, 2010 at 1:10pm
Hi Stoyan,
Thanks a lot for your suggestion. Now everything is fine.
Bala
