Normal Topic Nodes overlap in SpringLayout (Read 5582 times)
abereznyi
Mar 22nd, 2010 at 3:47pm
I set my nodes size to about 200 by 60, as I want to show some content in them.
I use SpringLayout Arrange() and then Diagram ResizeToFitItems() for layout but I can't make it to prevent nodes from overlapping.
Is there a way to make sure that nodes do not overlap after  SpringLayout Arrange() is called?
&&Thanks,&&Alex
Re: Nodes overlap in SpringLayout
Reply #1 - Mar 22nd, 2010 at 4:25pm
The following settings seem to work fine for such nodes in my test:
var sl = new SpringLayout();
sl.NodeDistance = 200;
sl.MinimizeCrossings = true;
sl.RepulsionFactor *= 100;
sl.Arrange(diagram);
Please send a sample diagram to support@mindfusion.eu if you still get bad results.
abereznyi
Reply #2 - Mar 22nd, 2010 at 8:27pm
sl.RepulsionFactor is 0 and multiplying it by any factor is still 0, so nothing changes.
I tried to set RepulsionFactor to numbers like +-100, +-50, +-200, +-10, +-1 etc.
The node overlap is always much worse than with default value RepulsionFactor=0.
Setting EnableClusters = true improves layout some,
but I still can't get rid of node overlap...
&&Thanks,&&Alex
Reply #3 - Mar 23rd, 2010 at 9:31am
This is what I get with a small test graph:
If you need to arrange larger and/or denser graphs, you will have to set a larger IterationCount.
In any case, this layout class does nothing to prevent overlapping, but just simulates some repulsion and spring forces. You might try using AnnealLayout instead - it creates similar results, but you have more control over criteria such as overlapping nodes and links through the various cost properties.
abereznyi
Reply #4 - Mar 23rd, 2010 at 7:39pm
Yes AnnealLayout is much nicer, but it's VERY slow.
I make diagrams with 25-50 nodes and it can go for 10 sec or more on high-end machine.
Also it occasionally put all the nodes in one narrow horizontal strip at the top  of the diagram right on top of each other - I suspect there is some bug there.
I designed a compromise by using both layouts with AnnealLayout  running with very few iterations to correct shortcomings of SpringLayout:
                            NodeDistance = 200,
                            MinimizeCrossings = true,
                            RepulsionFactor = 0,
                            IterationCount = 500,
                            EnableClusters = true,
                            Anchoring = Anchoring.Reassign
           var al = new AnnealLayout
                            Anchoring = Anchoring.Reassign,
                            BoundaryFactor = 100000,
                            CrossingLinksCost = 300000,
                            DistributionFactor = 100000,
                            KeepGroupLayout = false,
                            IterationsPerStage = 5,
                            LinkLengthFactor = 0.10, // larger makes shorter links
                            NodeLinkCrossingCost = 250000,
                            NodeLinkDistFactor = 500000,
                            Randomize = false,
                            Stages = 10
           al.Arrange(diagram);
           diagram.ResizeToFitItems(50);
I do add a few nodes by clicking my button on my control node, which connects one or more new nodes with current node.
Is there a way to keep layout as close as possible to the layout before adding a node or two?
All nodes often end up in completely different places which is hard for users to follow.
&&Thanks,&&Alex
Reply #5 - Mar 23rd, 2010 at 8:50pm
Try to initially place the new node at the median position of its neighbor nodes if they are more than one, and run AnnealLayout with lower InitialTemperature value for just a few stages. If the new node has one neighbor, move it somewhere near the already arranged neighbor. If the new node is not connected at all to other nodes, place it somewhere outside the union of all nodes rectangles.
Reply #6 - Mar 24th, 2010 at 9:45am
We have ported a SpringLayout feature from the WinForms version that could help for that:
https://mindfusion.eu/_beta/diaglite14_spring.zip
Now when you need to add only a few nodes to the layout, you can set node.LayoutTraits[SpringLayoutTraits.Frozen] = true for the already arranged nodes. The layout method keeps such nodes where they are, but still considers the forces they exert in the simulated system, so the newly added nodes should be placed at a suitable position in the layout. Then you might run just a few additional iterations with the Frozen flag removed to adjust the positions of nodes adjacent to the newly added ones.
abereznyi
Reply #7 - Mar 25th, 2010 at 3:02pm
I tried SpringLayoutTraits.Frozen, and it seems to improve layout a bit,
but this beta version has a problem: all images inside my control nodes and all its child controls are not visible, so I'll have to wait until it's fixed.
&&Thanks,&&Alex
Reply #8 - Mar 25th, 2010 at 3:06pm
Do you mean the images disappear from user-controls hosted in ControlNodes?
abereznyi
Reply #9 - Mar 25th, 2010 at 3:29pm
Sorry my bad, I take it back:  it was my bug.
http://mindfusion.eu/Forum/Forum/images/smiley.gif
&&Thanks,&&Alex
