Normal Topic Export and Print The Diagram (Read 4739 times)
Sachin
Mar 24th, 2010 at 12:54pm
HI
   I am using Vs 2010 , and Silverlight 4.0
In silverlight 4 Print option is there  so i  used to print the Diagram,
my question whether Diagramlite will support print FUnctionality default?
because what i need is if my Diagram is huge it should automatically wrap and go to the Next page,
previously we are used GoDiagram in Windows it behave like that, so samething expecting here,
another one is
Export current we created the service and passing the xmlNode and Save as the  image then i am showing the image,
is it possible  any easy way to export the diagram to any image format,
did  you have any plan  for this activity?
thanks
murugan
Re: Export and Print The Diagram
Reply #1 - Mar 24th, 2010 at 2:36pm
Printing will be available in V1.5 next month.
At this time you can create a PNG on the client side, or any other image format supported by .NET on the server.
Sachin
Reply #2 - Apr 6th, 2010 at 6:48am
HI
Can you able to tell me When is your V1.5 Release
Reply #3 - Apr 6th, 2010 at 8:20am
Later this month. We should have a beta version of the control with printing support next week.
Sachin
Reply #4 - Apr 6th, 2010 at 12:53pm
hi
glad to hear what about Client Side Export ?
Sachin
Reply #5 - Apr 16th, 2010 at 3:02pm
Hi
As you said earlier   u r going to release the Beta version of the control this week
when will we get the Dlls  for testing the client side Export and Printing Functionality ...
Regards
sachin
Reply #6 - Apr 21st, 2010 at 9:40am
This version adds Diagram.Print() method:
https://mindfusion.eu/_beta/diaglite15_print.zip
It requires the released Silverlight 4 RTW version.
Sachin
Reply #7 - Apr 21st, 2010 at 1:44pm
HI
I tried printing it is working fine.. Good Work :)
also  i  need Client side Export , currently i am doing server side export, if i get that one also
it is very good for our project....
Thanks sachin
Reply #8 - Apr 21st, 2010 at 5:12pm
I'm afraid we can't do anything about client side image export, until Silverlight provides some image encoders. What you can do is call CreateImage to get a WritebleBitmap representing the diagram, and then save that as an image using a third party library, e.g. check this:
http://blog.blueboxes.co.uk/2009/07/21/rendering-xaml-to-a-jpeg-using-silverligh...
