Normal Topic Selection rectangle is not visible (Read 1400 times)
kaykay15
Apr 22nd, 2010 at 10:21am
Hello Team,
When the diagram behavior is in modify mode, when i try to select multiple nodes, the selection rectangle is drawn behind  the diagram as show in the below link
http://docs.google.com/leaf?id=0B4xAPIW5oeouOGM4ZThiOWYtMjM4OC00YjI2LTkyNDItNDhk...
how do i get that selction rectangle above the diagram so that the user is aware that he is selecting some nodes.
-KayKay
Thanks,&&-KayKay
Re: Selection rectangle is not visible
Reply #1 - Apr 22nd, 2010 at 11:18am
Use this workaround for now:
private void diagram_MouseMove(object sender, MouseEventArgs e)
	var diagVisuals = diagram.DocumentPlane.Children;
	var selectionRect = diagVisuals[diagVisuals.Count - 1] as Rectangle;
	if (selectionRect != null)
		Canvas.SetZIndex(selectionRect, 100000);
