Normal Topic How to Import Visio [.vxd] in .Net Diagram (Read 5254 times)
khurramdbg
Mar 30th, 2010 at 9:11am
Hi I want to import visio .vxd file into .net diagram. any help.
Re: How to Import Visio [.vxd] in .Net Diagram
Reply #1 - Mar 30th, 2010 at 10:32am
Add a reference to MindFusion.Diagramming.Import.Visio.dll, create a VisioImporter instance and call its ImportPage method.
khurramdbg
Reply #2 - Mar 30th, 2010 at 10:45am
System.Xml.XmlException was caught
  Message="Data at the root level is invalid. Line 1, position 1."
  Source="System.Xml"
  LineNumber=1
  LinePosition=1
  SourceUri=""
  StackTrace:
      at System.Xml.XmlTextReaderImpl.Throw(Exception e)
      at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
      at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
      at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
      at System.Xml.XmlTextReaderImpl.Read()
      at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
      at System.Xml.XmlDocument.Load(XmlReader reader)
      at System.Xml.XmlDocument.LoadXml(String xml)
      at MindFusion.Diagramming.Import.VisioImporter.ImportPage(String vdxPathName, Diagram diagram, Int32 PageIndex)
      at MindFusion.Diagramming.Import.VisioImporter.ImportAllPages(String vdxPathName, Diagram diagram)
getting this exception. any Help
Reply #3 - Mar 30th, 2010 at 11:30am
VisioImporter only supports Visio XML Drawing files (VDX extension). Are you sure your file was saved in XML format?
