Normal Topic Layout of containers inside container (Read 3196 times)
sledenev
Apr 13th, 2010 at 12:28pm
For my task I need to create parent ContainerNode and put inside two (N in general) child ContainerNodes and layout child containers inside parent container.
But before closed/open container action main group looks weird: first child is inside of parent, second child attached outside.
Please, see my code below. Thanks in advance.
ContainerNode mainContainer = new ContainerNode();
ContainerNode childContainer1 = new ContainerNode();
ContainerNode childContainer2 = new ContainerNode();
diagram1.Nodes.Add( mainContainer );
diagram1.Nodes.Add( childContainer1 );
diagram1.Nodes.Add( childContainer2 );
mainContainer.Add( childContainer1 );
mainContainer.Add( childContainer2 );
DiagramItemCollection arranger = new DiagramItemCollection
childContainer1, childContainer2
GridLayout fl1 = new GridLayout();
fl1.Arrange( diagram1, arranger );
Re: Layout of containers inside container
Reply #1 - Apr 13th, 2010 at 1:08pm
You'll need to call the parent container's UpdateBounds method.
sledenev
Reply #2 - Apr 15th, 2010 at 8:55am
Stoyo wrote on Apr 13th, 2010 at 1:08pm:
Thank you, it works.
But I have another question. I have arranged tree of shapenodes and need to put this tree inside the container and keep their layout. I've tried several ways and cant succeed: nodes just overlapped with each other. What am I doing wrong?
Reply #3 - Apr 15th, 2010 at 10:50am
Do you need to move the tree to a container programmatically? It should look like this:
foreach (DiagramNode node in treeNodes)
     container.Add(node);
sledenev
Reply #4 - Apr 15th, 2010 at 11:47am
Stoyo wrote on Apr 15th, 2010 at 10:50am:
I do exactly like you said, but the result is not one that I expect. That's my code:
ContainerNode container = new ContainerNode( diagram1 );
ShapeNode s1 = new ShapeNode( diagram1 );
ShapeNode s2 = new ShapeNode( diagram1 );
DiagramLink link = new DiagramLink( diagram1, s1, s2 );
diagram1.Nodes.Add( s1 );
diagram1.Nodes.Add( s2 );
diagram1.Links.Add( link );
diagram1.Nodes.Add( container );
DiagramItemCollection arrange = new DiagramItemCollection { s1, s2 };
TreeLayout treeLayout = new TreeLayout( s1, TreeLayoutType.Centered );
treeLayout.Arrange( diagram1, arrange );
container.Add( s1 );
container.Add( s2 );
container.UpdateBounds( true );
GridLayout gridLayout = new GridLayout();
gridLayout.Arrange( diagram1 );
Reply #5 - Apr 15th, 2010 at 1:09pm
Set arrange = new DiagramItemCollection { s1, s2, link } and it will work.
