Normal Topic Links disappear in tabcontrol (Read 1634 times)
e4b1
Apr 14th, 2010 at 11:07am
i experience a problem when i use diagrams in tabcontrol ( aswell in DivElements SandDock ). When i switch between tabs the DiagramLink elements (standard) seem to become transparent/hidden. The Link is still there and can be selected - when moving, it reappears and stays visible.
Can you confirm this behavior and if so, do you have an idea to make it work.
regards,
maik
Re: Links disappear in tabcontrol
Reply #1 - Apr 14th, 2010 at 12:14pm
I could not reproduce this. Are you doing anything in response to the TabControl.SelectionChanged event?
e4b1
Reply #2 - Apr 14th, 2010 at 3:08pm
thanks for your reply. I just found the problem myself, when i run the project on my recently reinstalled private notebook it worked as supposed. So the problem was/is my Silverlight Version (4.0.41108.0).
After manual update to Version 4.0.50303.0 everything is fine...
maik
