Normal Topic Image in Row Header of LaneGrid (Read 1819 times)
Aziz ur Rahman
Apr 15th, 2010 at 10:02am
Is there any way to show an image in row header of LaneGrid. I was thinking to add a shapenode in the row header but it does not seems possible.
Is there any other solution?
Syed Aziz ur Rahman
Re: Image in Row Header of LaneGrid
Reply #1 - Apr 15th, 2010 at 11:14am
Try assigning a TextureBrush to the header's Style.
Aziz ur Rahman
Reply #2 - Apr 15th, 2010 at 12:19pm
Thanks. it worked. Is there an easy way to resize the image to fit the header. TextureBrush.WrapMode does not help that much.
Do I have to get the Row Header Bounds somehow and resize the image myselfe before passing it to TextureBrush?
Any other method?
Syed Aziz ur Rahman
Reply #3 - Apr 18th, 2010 at 7:29am
You can resize a Bitmap image as shown here:
http://www.vb-helper.com/howto_net_image_resize.html
Another option to show an image over a header is to handle the diagram's DrawForeground event and call DrawImage(img, GetHeaderBounds(...)).
