Normal Topic Not able to find ZoomToFit() method for diagram (Read 1858 times)
kaykay15
Apr 16th, 2010 at 6:16am
While searching for zoom in forums i found ZoomToFit() method, but i am not able to find this method for the diagram, is that method updated or should i call any other method to fit the diagram to the available space.
-KayKay
« Last Edit: Apr 16th, 2010 at 7:50am by kaykay15 »
Thanks,&&-KayKay
kaykay15
Re: Not able to find ZoomToFit() method for diagra
Reply #1 - Apr 16th, 2010 at 7:49am
Hey I found a workaround to implement zoomtofit method
this is working fine...
while (scrollViewer.ScrollableWidth != 0 || scrollViewer.ScrollableHeight != 0)
               diagram.ZoomFactor -= 1;
               scrollViewer.UpdateLayout();
               if (diagram.ZoomFactor <= 1)
                   break;
-KayKay
Thanks,&&-KayKay
Reply #2 - Apr 16th, 2010 at 8:09am
ZoomToFit is not available in the Silverlight control. You could try using the ZoomToRect method instead:
diagram.ZoomToRect(diagram.GetContentBounds(false, true));
kaykay15
Reply #3 - Apr 16th, 2010 at 10:45am
That works... Thanks
Thanks,&&-KayKay
