Normal Topic Sample Code for TreeLayout Demo (Read 7822 times)
nagarjuna
Jan 3rd, 2014 at 7:36am
Can i get the sample code for the TreeLayout shown in one of those demos given by mindfusion(mindfusion.eu/demos/diagramlite)
Thanks in Advance.
Re: Sample Code for TreeLayout Demo
Reply #1 - Jan 3rd, 2014 at 8:05am
You should have that code installed together with other sample projects under C:\Program Files\MindFusion\Diagramming for...\VS20**\Samples folder. Here's the code anyway:
public partial class Page : UserControl
    public Page()
        InitializeComponent();
    private void OnPageLoaded(object sender, RoutedEventArgs e)
        diagram.DefaultShape = Shapes.Rectangle;
        diagram.LinkHeadShape = ArrowHeads.Triangle;
        rootNode = new ShapeNode(diagram);
        diagram.Nodes.Add(rootNode);
        rootNode.Image = image1.Source;
    private void image_OnMouseDown(object sender, MouseButtonEventArgs e)
        draggedImage = sender as Image;
        CaptureMouse();
    private void OnMouseMove(object sender, MouseEventArgs e)
        if (draggedImage != null)
            Point diagramPosition = e.GetPosition(diagram);
            DiagramNode parent = diagram.GetNodeAt(diagramPosition);
            if (parent != null)
                Cursor = Cursors.Eraser;
            else
                Cursor = Cursors.Hand;
        else
            Cursor = Cursors.Arrow;
    private void OnMouseUp(object sender, MouseButtonEventArgs e)
            ReleaseMouseCapture();
            if (parent != null)
                ShapeNode child = new ShapeNode(diagram);
                child.Image = draggedImage.Source;
                diagram.Nodes.Add(child);
                DiagramLink link = new DiagramLink(diagram, parent, child);
                diagram.Links.Add(link);
                var layout = new MindFusion.Diagramming.Layout.TreeLayout();
                layout.Arrange(diagram);
        draggedImage = null;
    private ShapeNode rootNode;
    private Image draggedImage;
nagarjuna
Reply #2 - Jan 3rd, 2014 at 9:43am
Thanks Stoyo, that was really helpful.
Now, I am able to do a tree layout in silverlight Smiley
