Normal Topic Node connectivity issues with GridRouter (Read 1667 times)
Chandermani
Apr 26th, 2010 at 11:35am
I am using GridRouter with default settings to route links in the diagram. It is giving some issues in some cases which i am not understanding. I am attaching a screen shot for you to look at the output.
http://docs.google.com/leaf?id=0B59ctf4e17gZMzgyM2MwYjAtMzhiNC00ZDM3LWJlMWQtZThi...
Chandermani
Re: Node connectivity issues with GridRouter
Reply #1 - Apr 26th, 2010 at 12:18pm
Try using a smaller RoutingOptions.GridSize value and a higher NodeVicinityCost. You have set Obstacle = false for the background nodes, right?
Chandermani
Reply #2 - Apr 26th, 2010 at 12:50pm
Fine i would try what you have mentioned. Yes for background shapes visible in the image i shared all of them have Obstacle=false for background nodes
