Normal Topic Inconsistent Sizing (Read 1655 times)
choohj70
Inconsistent Sizing
May 7th, 2010 at 6:44pm
When I first load shapes from a database, I use the following code to optimize the shape size.
Node.ResizeToFitText(FitSize.KeepRatio)
And if it is edited, the following code re-optimizes the shape size.
var newFSize = applet().getScriptHelper().getConstant('FitSize', 'KeepRatio');
node.resizeToFitText(newFSize);
However, the first one has nice spacing around the text and second one doesn't, is there anyway to have consistent spacing around the two?
Thank you,
Re: Inconsistent Sizing
Reply #1 - May 7th, 2010 at 7:08pm
The resizeToFitText Java code is pretty much the same as the .NET's one, but perhaps the .NET text measuring methods report a slightly larger text layout rectangle. You could add a few pixels to the node's width and height after calling the applet's fitText method to make the node a bit larger.
choohj70
Reply #2 - May 8th, 2010 at 12:39am
Thank you. I will try that approach.
