Normal Topic Contacts connected with the Appointement (Read 5199 times)
TwAwE
Jun 3rd, 2010 at 12:18pm
Hi, I am a new entry, I come from Italy, sorry for my english.
I know how I can insert a contact on a Timetable control using vb.net but  I do not understand how can I connect it with a particular appointement.
I have tried to set the id of the appointement as id of the contact but do not exist the method to get it directly through the id, but only by index, and the problem is that when I want make some operation on the contact I must cicling all the contacts collection.
If you can help my also with the simple code i better.
Thanks in advance
Re: Contacts connected with the Appointement
Reply #1 - Jun 3rd, 2010 at 12:35pm
To associate a contact with an item, add that contact to the Contacts collection of the item. The following code illustrates how:
i.Contacts.Add(c)
Let me know if this helps.
TwAwE
Reply #2 - Jun 3rd, 2010 at 3:32pm
I use an xml file as datasource for the timetable control and when I create an item (appointement) if I use the follow code, the contact do not be registrered on a file.
I post the code to create a new appointement with an associated contacts
                'Reset the drag drop
                Me.Calendar.ResetDrag()
                'Oggetto / HeaderText
                e.item.HeaderText="MyTitle..."
                'Descrizione /DescriptionText
                 e.item.DescriptionText="MyDescription..."
                'Dichiaro un nuovo contatto / Declare a new contact
                Dim c As New Contact
                'Imposto i valori del contatto appena creato
                With c
                    .Id = e.item.Id
                    .Address = "MyAddress..."
                    .Email = "MyMail..."
                    .FirstName = "..."
                    .LastName = "..."
                    .Name = "..."
                    .Phone = "..."
                End With
                'Set the contact on the item
                e.item.Contacts.Add(c)
                'Start the process to create a file contains the appointement and the contacts
                Dim path As String = ....
                Dim a As New Xml.XmlDocument
                Schedulatore.Schedule.SaveTo(path.ToString, ContentType.Xml)
If at the code I add the follow row
Me.Calendar.Contacts.Add(c)
The contact, when I create the file, is registrered, but I dont Know how can I filter the contact with the item click and eventually modified or deleted the record match
Reply #3 - Jun 4th, 2010 at 6:34am
I am not sure what you mean by "filter the contact with the item click".
You can access the contacts associated with the clicked item through the Item.Contacts collection. Then, when an item is clicked, you can inspect its associated contacts and perform the necessary operations.
TwAwE
Reply #4 - Jun 7th, 2010 at 1:19pm
Hi, I am come back,
I try to explain my problem with the code that I have writed(The follow code was been simplified):
On the event ItemCreated...
Private Sub Calendario_ItemCreated(ByVal sender As Object, ByVal e As MindFusion.Scheduling.ItemEventArgs) Handles Calendario.ItemCreated
        Try
            e.Item.HeaderText = "MyItem.."
            With c
                .Id = e.Item.Id
                .Address = "Via chiusa..."
                .Email = "tavolonimarco@alice.it"
                .FirstName = "MyContacts.."
                .LastName = ""
                .Name = ""
                .Phone = "3285341..."
            End With
            Dim NTask As New Task
    'Add the contact at the item
            e.Item.Contacts.Add(c)
        Catch ex As Exception
            MsgBox(Err.Description, MsgBoxStyle.Critical, "Errore " & Err.Number)
        End Try
    End Sub
On the event ItemDeleting...
Private Sub Calendario_ItemDeleting(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.ItemConfirmEventArgs) Handles Calendario.ItemDeleting
        Try
            'Delete the contact from the scheduler
            Me.Calendar.Contacts.Remove(e.Item.Contacts(0))
        End Try
    End Sub
After having used this routines i save the new data and then recharge my project from a file XML but
the contact created before and deleted exist still on a file.
The follow code is what I used to Save and Load the data
Try
            Dim myXmlTextWriter As XmlTextWriter
            myXmlTextWriter = New XmlTextWriter(Percorso.ToString, System.Text.Encoding.UTF8)
            myXmlTextWriter.Formatting = System.Xml.Formatting.Indented
            myXmlTextWriter.WriteStartDocument(False)
            myXmlTextWriter.WriteComment("Appuntamenti utente " & CodiceUtente.ToString)
            myXmlTextWriter.WriteStartElement("Appointements")
            myXmlTextWriter.WriteEndElement()
            myXmlTextWriter.Flush()
            myXmlTextWriter.Close()
            Calendar.SaveTo(MyPath.ToString, ContentType.Xml)
        End Try
Try
            Calendar.LoadFrom(MyPath.ToString, ContentType.Xml)
        End Try
Reply #5 - Jun 7th, 2010 at 2:23pm
I will try to explain how the resource system in MindFusion.Scheduling works. To simplify the description I will focus on contacts, but the same rules apply to the other three types of resources.
All contacts should be present in the Schedule.Contacts object. The contacts that you want to group by should be added to the Calendar.Contacts collection. If you add a contact to Calendar.Contacts and this contact is not present in Schedule.Contacts, it is automatically added there. Therefore, when you call:
this contact is also automatically added to Calendar.Schedule.Contacts. In other words, to completely delete a contact, you have to remove it from the Schedule.Contacts collection too.
TwAwE
Reply #6 - Jun 7th, 2010 at 7:27pm
Yes, I understand the structure of the scheduler but when I add an item as appointement that contains a Task or others resources, them are not insert automatically on the file.
To add some contact I Have to insert trought the Schedule.Contacts.Add method and I know how call group by an appointement but when I use Schedule.Contacts.Remove methods there is a problem beacouse it do not work.
If you want, you give my your e-mail address and I try to send you the project.
So you can check the problem
Thanks in advance.
Reply #7 - Jun 8th, 2010 at 5:52am
Feel free to send the project to meppy@mindfusion.eu.
TwAwE
Reply #8 - Jun 13th, 2010 at 12:48pm
Thanks for your help, you have been very friendly.
