Normal Topic Reclaim Memory Consumption of diagram (Read 1247 times)
solisgsandc
Jun 8th, 2010 at 7:23pm
Is there some sort of cache invloved when creating new nodes in a diagram. It seems like when I create 100 nodes and 100 links at a time programmatically, the memory consumption increases. It is reclaimed when I minimize the window where the diagram is hosted. I need to know how I can reclaim this memory programatically so that I can add more nodes without the need to minimize the window manually.
Re: Reclaim Memory Consumption of diagram
Reply #1 - Jun 9th, 2010 at 5:03am
I suppose the .NET garbage collector runs when you minimize the window. You can run it explicitly by calling GC.Collect(), though the runtime should call it automatically when it needs more memory.
