Normal Topic Version 3.0.2 beta (Read 1156 times)
Version 3.0.2 beta
Jul 26th, 2013 at 7:52am
Version 3.0.2 adds the following customer-requested features:
Import Visio 2003 XML drawings
VisioImporter allows importing Visio 2003 XML Drawing files (*.vdx) into WpfDiagram. The standard Visio flowchart shapes, as well as most of the UML and Database entity shapes are imported to their closest representation in the MindFusion.Diagramming object model. The Visio connectors are imported as DiagramLink objects, preserving the relationship between the connected nodes. In addition, most of the attributes of Visio objects such as text, text formatting, fill and line colors and styles are preserved. The component raises an event for each imported node to let you set the node shape if it is not recognized by MindFusion.Diagramming or if you need to set a different shape.
The Import method imports all Visio pages into a DiagramDocument, creating a DiagramPage for each page from the VDX. To determine how many pages there are in a Visio document and import only a single page, call the GetPageCount and ImportPage methods. All pages of a Visio drawing can be imported into a single Diagram by calling the ImportAllPages method, which lays out the pages as set in PagesPerRow.
~ AttachTo overloads that attach nodes to link segments or control points now allow specifying negative index values. Negative values are interpreted as relative to the last point or segment, regardless of the current number of link segments. For example, -2 denotes the second-to-last point or segment.
~ Improved handling of clip paths in PdfExporter.
~ The swimlane grid can be exported to Visio by setting the ExportLanes property of VisioExporter.
~ The Copy method lets you copy text attributes between objects implementing the ITextAttributes interface, such as diagram items, table cells and tree items.
~ Improved placement of link labels along shorter link segments.
~ The ArrangeLinkLabels method rearranges link labels whose AutoArrange flag is set.
If anyone is interested in trying the beta version, please download this archive, containing updated help file and control assemblies:
https://mindfusion.eu/_beta/WpfDiagram302.zip
