Normal Topic Disable meetings sharing 1 slot (Read 2962 times)
Nick
Jun 30th, 2010 at 2:36pm
Hi.
I want to dissallow two or more scedule items from sharing the same time slot. Is it possible to do using the control or should I just try to do it in the surrounding code?
Many thanks
Nick
Re: Disable meetings sharing 1 slot
Reply #1 - Jul 1st, 2010 at 9:12am
Try to handle the Calendar.ItemsModifying event and cancel the operation if the item being modified will collide with another item. Here is a sample code illustrating how you could do this:
private void Calendar_ItemModifying(object sender, ItemModifyConfirmEventArgs e)
	var items = c.Schedule.GetAllItems(e.Item.StartTime, e.Item.EndTime);
	for (int i = 0; i < items.Count; )
		if (items[i] == e.Item)
			items.RemoveAt(i);
			continue;
		if (items[i].StartTime == e.Item.EndTime)
			items.RemoveAt(i);
			continue;
		i++;
	e.Confirm = items.Count == 0;
Let me know if this works.
Nick
Reply #2 - Jul 2nd, 2010 at 8:30am
Works like a charm!! Thank you
