Normal Topic ResizeToFitItems and drag drop (Read 2194 times)
ChrisGC
Jul 2nd, 2010 at 5:21pm
I am evaluating diagramlite. I have a project whereby i am creating nodes and links programatically followed by LayeredLayout.Arrange, diagram.ResizeToFitItems and diagram.ZoomToRect:
[code] var layout = new LayeredLayout(MindFusion.Diagramming.Silverlight.Layout.Orientation.Vertical, 80, 250, new Size(10, 10));
layout.LinkType = LayeredLayoutLinkType.Cascading;
layout.Arrange(diagram);
diagram.ResizeToFitItems(5);
diagram.ZoomToRect(diagram.Bounds);
[/code]
I also have a code based on the drag/drop sample which allows me to manipulate the nodes.
However due to diagram.ResizeToFitItems and diagram.ZoomToRect the drag hit test is not accurate. ([b]it is without those method calls[/b]). It seems to be failing here:
[code]
void diagram_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
ShapeNode node = diagram.GetNodeAt(e.GetPosition(diagram)) as ShapeNode;
if (node == null)
return;
[/code]
i.e diagram.GetNodeAt(e.GetPosition(diagram)) is no longer accurate and dispite clicking on a node, GetNodeAt returns null....
This can all be seen be adding the following to the drag drop demo:
[code] private void diagram_NodeCreated(object sender, NodeEventArgs e)
[/code]
and adding the attribut on the diagram markup:
NodeCreated="diagram_NodeCreated"
Please can you advise?
Thanks in advance
Re: ResizeToFitItems and drag drop
Reply #1 - Jul 2nd, 2010 at 5:25pm
Try using e.GetPosition(diagram.DocumentPlane) instead.
ChrisGC
Reply #2 - Jul 2nd, 2010 at 5:51pm
Stoyo - perfect!!!
Thanks for the quick response.
