Normal Topic Loading a diagram is giving an Exception. (Read 1712 times)
padmavathi
Jul 6th, 2010 at 5:24am
Hi
I have created a Silverlight application into which I want to load a Diagram through xml file.
This is what my LoadDiagram logic:
private void btnLoadClick(object sender, RoutedEventArgs e)
    OpenFileDialog openFileDlg = new OpenFileDialog();
   bool? isOpenFileDlgShown = openFileDlg.ShowDialog();
       if (isOpenFileDlgShown == true)
                   FileInfo file = openFileDlg.File;
                   using (var stream = file.OpenRead())
                       diagram.LoadFromXml(stream);
But when I run this I am getting the following exception:
{System.NullReferenceException: Object reference not set to an instance of an object.
   at MindFusion.Diagramming.Silverlight.Diagram.LoadFromXml(XDocument document)
   at MindFusion.Diagramming.Silverlight.Diagram.LoadFromXml(Stream stream)
   at LoadDiagram.MainPage.btnLoadClick(Object sender, RoutedEventArgs e)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEve
ntArgs e)
   at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)}
Here the xml file iam trying to load is an xml file created/saved from another silverlight applicaton.
The thing i don't understand here If I try this from the earlier application where i am saving, i could able to load.
But when i do this in another application, the above mentioned exception is coming.
What is missing here, can anyone help me out?
Thanks & Regards
Padma
Re: Loading a diagram is giving an Exception.
Reply #1 - Jul 6th, 2010 at 5:52am
If you are using any custom node types, you should add them to all applications that are expected to load this file, and also call the RegisterItemClass method when the applications load. RegisterItemClass maps the element names from the diagram xml file to the node classes you are using.
padmavathi
Reply #2 - Jul 6th, 2010 at 12:32pm
Yes ..you are rigjht. I fotgot to call the RegisterItemClass.
Its working now.
Thanks & Regards
Padma
