Normal Topic How to work with DrawNode event? (Read 1602 times)
chiru29
Jul 23rd, 2010 at 11:17am
In the earlier version of FlowchartX, we are using DrawBox event.
We are upgrading to latest version. So, i have updated this event to DrawNode event; which is not firing when i draw the node from code.
(It is mentioned that it will be raised when a diagram node must be custom drawn).
How can i make this event fire? OR is there any appropriate event for this which has the arguments similar to DrawNodeEventArgs ?
Thanks & Regards
Chiru
Re: How to work with DrawNode event?
Reply #1 - Jul 23rd, 2010 at 11:28am
Have you set the ShapeNode.CustomDraw property?
chiru29
Reply #2 - Jul 23rd, 2010 at 11:37am
Thanks. Its working with setting this property.
Chiru
