Normal Topic Err java.util.ConcurrentModificationException (Read 3782 times)
ihernandj
Jul 29th, 2010 at 7:56pm
I'm trying to create several diagramas in several files and sometimes I receive this message "java.util.ConcurrentModificationException
       at java.util.AbstractList$Itr.checkForComodification(AbstractList.java:372)
       at java.util.AbstractList$ListItr.set(AbstractList.java:409)
       at java.util.Collections.sort(Collections.java:163)
       at com.mindfusion.pdf.PdfPage.Save(Unknown Source)
       at com.mindfusion.pdf.PdfDocument.Save(Unknown Source)
       at com.mindfusion.pdf.PdfGraphics2D.dispose(Unknown Source)
       at java.awt.Graphics.finalize(Graphics.java:1147)
       at com.mindfusion.pdf.PdfGraphics2D.finalize(Unknown Source)
       at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
       at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
       at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
       at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
       at java.util.AbstractList$Itr.next(AbstractList.java:343)
       at java.util.Collections.sort(Collections.java:162)
Do you know why it is happening?
thanks...
Re: Err java.util.ConcurrentModificationException
Reply #1 - Jul 30th, 2010 at 5:56am
Are you creating the pdf files from the Swing UI thread?
ihernandj
Reply #2 - Aug 8th, 2010 at 9:36pm
I am using awt and pdf export, I need to create a diagram with 130 pages, but if I create one file with 130 pages the process takes a lot of time that's why I'm creating one diagram with one page. Sometimes I receive the error and one or two files are incomplete.
Thank you.
Ignacio.
Reply #3 - Aug 9th, 2010 at 2:58pm
Could you check if this version works any better -
https://mindfusion.eu/_beta/jdiag311.zip
