Normal Topic Issues with Shadows (Read 2064 times)
SCooper
Issues with Shadows
Aug 13th, 2010 at 7:48am
Hi, we have noticed that a white ShapeNode with a transparent boarder on a white view show a slither of shadow even when the shadow offsets are set to 0, 0.
We don't want to set the shadow transparent too since the users have the option to locate the shadow to the corners.
Is there something we should be doing to avoid showing this shadow outline?
Many thanks,
Steve
Re: Issues with Shadows
Reply #1 - Aug 13th, 2010 at 12:01pm
Are you setting the node's Pen.Color to transparent to hide the border? In order to render shadows as big as the nodes when Pen.Width is large, the shadow shape is always drawn with a pen of the same thickness but with color set to the item's ShadowColor/Brush, so I suppose that's what you are seeing. As a work-around you'll have to set ShadowBrush to null when the shadow offsets are set to 0.
SCooper
Reply #2 - Aug 13th, 2010 at 12:41pm
In the version we are using we only have access to ShadowColor.
When we set the Pen.Color to either transparent or White we can see the shadow, though with transparent it is much more noticable.
We don't really want to hide the shadow, since the offsets could be non-zero, just to make sure its is fully hidden when they are.
Reply #3 - Aug 13th, 2010 at 1:44pm
I can't think of any other solution. Just set ShadowColor to Transparent when the offsets become 0 and restore it back to the original color when they are greater than 0.
