Normal Topic Root Node (Read 2784 times)
kdr35
Root Node
Aug 16th, 2010 at 7:44am
I need to set one node as root before graph load so that node must be undeleted , How I can do undeleted one node.
I try to do in NodeDelete event as look node id but it doesnt work ı can control node id but I cant stop node delete event so node is deleted.
Re: Root Node
Reply #1 - Aug 16th, 2010 at 8:20am
You can prevent the user from deleting a node by handling the NodeDeleting event. However, it is not raised when deleting nodes by code, or when loading files. You will have to create a new root node after calling LoadFromFile or ClearAll.
kdr35
Re: Root Node
Reply #2 - Aug 16th, 2010 at 8:29am
I dont need to delete node via code , i use only interface to delete node.
I tried to prevent in NodeDeleting Event ;
private void diagram1_NodeDeleting(object sender, NodeValidationEventArgs e)
if (e.Node.Id.ToString() == "0")// root node id
return;
But Node is deleted how i prevent to delete node in NodeDeleting Event .
Re: Root Node
Reply #3 - Aug 16th, 2010 at 9:12am
A 'return' is not enough. You should set the Cancel property of the event-args object.
kdr35
Re: Root Node
Reply #4 - Aug 16th, 2010 at 10:16am
thanks
