Normal Topic Removing Group not working (Read 3934 times)
srinivas
Aug 18th, 2010 at 2:27pm
I am getting the error saying "Cannot remove the specified item because it was not found in the specified collection".
Please let me know how to delete multiple items selected in the diagram. It is working find for all other nodes except that if I select a Group and any other node in combination I am getting the above error.
I have DelKeyAction set to MindFusion.Diagramming.DelKeyAction.DeleteSelectedItems. I am clicking on Del key after selecting two nodes.
I am using latest MindFusion.Diagramming control version 5.3.5.
Plese suggest a solution, thanks in advance.
Regards
Velidanda
Re: Removing Group not working
Reply #1 - Aug 18th, 2010 at 3:24pm
Are you handling the NodeDeleted event?
srinivas
Reply #2 - Aug 19th, 2010 at 5:22am
NodeDeleted event is not handled in the code, removal of nodes is done in Form.ctxtMenuDelete.Click event, where the selected items are iterated and are getting removed from Diagram.Items collection.
Is this the right way of removing diagram items?
This was working fine with all other nodes but not working for the newly added DiagramGroup.
We have upgraded to use Group and I have a class DiagramGroup with a ShapeNode and Group objects and using this DiagramGroup class to draw the group and attach the nodes.
Actual issue is that when I add group and a node to the diagram and selecting both and clicking Delete button is throwing the error I mentioned in my earlier post.
Please le me know how to handle this correctly.
Reply #3 - Aug 19th, 2010 at 7:20am
Does the error happen when hitting Del on the keyboard, or when processing ctxtMenuDelete.Click?
srinivas
Reply #4 - Aug 19th, 2010 at 8:03am
Error is when running ctxtMenuDelete.Click event code, I am able to debug the code in ctxtMenuDelete.Click event.
Deletion is working fine for a diagram that I am designing but if I open a diagram that is previously saved and when I am trying to select the nodes and hit Delete, getting the error.
Reply #5 - Aug 19th, 2010 at 9:14am
Iterating diagram.Selection.Nodes and deleting each node might not work because this also modifies the Selection.Nodes collection. The framework does not allow removing collection elements while enumeration is in progress, so you must copy the Selection.Nodes elements to a new collection and then loop over the copy to delete nodes. Another possibility is to delete just the first node until the collection is empty:
while (diagram.Selection.Nodes.Count > 0)
	diagram.Nodes.Remove(diagram.Selection.Nodes[0]);
srinivas
Reply #6 - Aug 19th, 2010 at 9:40am
Selected nodes are taken into another collection as below
DiagramItemCollection SelectedObjects = _fcMap.Selection.Items.Clone();
and then iterating thru selected objects as below
for (int i = 0; (i<= (SelectedObjects.Count - 1));i++)
MindFusion.Diagramming.DiagramItem CurOb = SelectedObjects[i];
DeleteChartObject(CurOb);
and in DeleteChartObject method removing the node using _fcMap.Items.Remove(CurOb);
When will NodeDeleted event has to be executed?
Implemented NodeDeleted method but not getting the control there, can I raise NodeDeleted event from code similar to NodeCreated?
Reply #7 - Aug 19th, 2010 at 9:52am
Deleting a node automatically deletes any DiagramLinks connected to it, so you will get that exception if SelectedObjects[i] is a link that has already been deleted.
srinivas
Reply #8 - Aug 19th, 2010 at 1:22pm
Ok, got it working by removing other nodes except diagram item that has Group node first and then removed diagram items with Groups.
It was something difficult to locate the issue, NodeDeleted event was not required to be implemented.
Anyway it is working fine now, Thanks for your help.
