Normal Topic Set SelectedItem in ShapeListBox from outside (Read 1465 times)
mbuechler
Aug 20th, 2010 at 9:31am
Hi.
I use the ShapeListBox to define the Shape of my ShapeNode. I save the name of the shape I selected in the ListBox as a name in my database, and with ShapeConverter.ConvertFromString(string name) I get the shape again when loading the Data. But now I want the SelectedItem in the ShapeListBox to be the one I have selected. this should be set from outside.
So like: listbox.SelectedItem = ...
I tried it with the shape itself and a ShapeNode, but everytime the Property SelectedItem stays NULL.
How can I set the SelectedItem from outside?
Re: Set SelectedItem in ShapeListBox from outside
Reply #1 - Aug 20th, 2010 at 9:51am
It's a hack, but this will select the shape with the specified id:
ListBox listBox = shapeListBox1;
foreach(ShapeNode node in listBox.Items)
	if (node.Shape.Id == id)
		listBox.SelectedItem = node;
		break;
mbuechler
Reply #2 - Aug 20th, 2010 at 10:32am
Ah perfect. Thanks
