Normal Topic Move shapes with arrow keys (Read 4404 times)
Dexter
Aug 20th, 2010 at 7:45am
Hi there,
I have come with some code that moves shapes using arrow keys. But the result is not the same as moving the shape with the mouse, meaning the diagram does not scroll if the shape goes out of the visible part of the diagram. I have auto scroll set to true.
In general on the PreviewKeyDown event of the diagram view is the key is an arrow then I set the IsInputKey value to true. This will fire the key down, and key up event. In the PreviewKeyDown event I start an interaction on the shape I want to move. On the keyDown I call the update and isAllowed method on the interaction and on key up the complete method on the interaction. This work fine but he diagram does not scroll for the shape like when I move the shape with the mouse.
If in the Key events I send some messages, like mouse down, mouse move and mouse up, to scroll the diagram, I get an error "Value can not be null. Parameter name image".
Can any body give me an idea about this problem.
Dexter
Re: Move shapes with arrow keys
Reply #1 - Aug 20th, 2010 at 9:15am
Call view.ClientToDoc(view.ClientRectangle) to get the visible region of the diagram. Check if it contains the items' bounding rectangle, and if it doesn't, change either ScrollX or ScrollY depending on the arrow key:
left arrow: ScrollX -= viewRect.Left - itemsRect.Left;
right arrow: ScrollX += itemsRect.Right - viewRect.Right;
up arrow: ScrollY -= viewRect.Top - itemsRect.Top;
down arrow: ScrollY += itemsRect.Bottom - viewRect.Bottom;
Dexter
Reply #2 - Aug 20th, 2010 at 9:26am
Hi Stoyan,
You are correct abut this. It could be a solution.
Now during some testing to see if the code will work I see that the error about the image appears also if I move the shape with the keys (like I described) and I press the mouse left button. (to be clear: I DO NOT SEND THE MESSAGE mouse down)
Do you have any idea why?
Dexter
Reply #3 - Aug 23rd, 2010 at 8:23am
Could you copy your KeyDown handler code here?
Dexter
Reply #4 - Aug 23rd, 2010 at 8:38am
Hi Stoyan,
Here is the code for all the things I do:
[code]
    public partial class Form1 : Form
       private Timer t;
       private bool arrowKeyDown;
       private List<Keys> keyDown;
       private List<Keys> keyUp;
       public Form1()
           InitializeComponent();
       private void Form1_Load(object sender, EventArgs e)
           ShapeNode shape = new ShapeNode(this.diagram1);
           this.diagram1.Nodes.Add(shape);
           shape.Image = null;
           shape.Move(50, 50);
           this.diagram1.Selection.Change(shape);
           t = new Timer();
           t.Interval = 300;
           t.Tick += new EventHandler(time_Tick);
       private void time_Tick(object sender, EventArgs e)
           t.Stop();
           List<int> downKeysASCII = this.keyDown.Select(p => (int)p).Distinct().OrderBy(p => p).ToList();
           List<int> upKeysASCII = this.keyUp.Select(p => (int)p).Distinct().OrderBy(p => p).ToList();
           if (downKeysASCII.SequenceEqual(upKeysASCII) && this.diagram1.Interaction != null)
               arrowKeyDown = false;
               Console.WriteLine("Save");
               DiagramNode firstNode = this.diagram1.Selection.Nodes[0];
               this.diagram1.Interaction.Complete(firstNode.GetCenter(), this.diagram1);
               this.diagram1.Interaction = null;
               this.diagram1.Invalidate();
       private void diagramView1_KeyDown(object sender, KeyEventArgs e)
           this.keyDown.Add(e.KeyData);
           if (arrowKeyDown)
               PointF firstNodeCenter = firstNode.GetCenter();
               if (e.KeyCode == Keys.Right)
                   firstNodeCenter.X += 4;
               if (e.KeyCode == Keys.Left)
                   firstNodeCenter.X -= 4;
               if (e.KeyCode == Keys.Down)
                   firstNodeCenter.Y += 4;
               if (e.KeyCode == Keys.Up)
                   firstNodeCenter.Y -= 4;
               Cursor.Position = diagramView1.PointToScreen(this.diagramView1.DocToClient(firstNodeCenter));
               //uint lParam = MakeLong(Cursor.Position.X, Cursor.Position.Y);
               //SendMessage(this.diagramView1.Handle, (int)Msgs.WM_MOUSEMOVE, 0, lParam);
               // Cursor.Position = newCursorPosition;
               if (e.KeyData == Keys.Escape)
                   this.diagram1.Interaction.Cancel(this.diagram1);
               else
                   this.diagram1.Interaction.Update(firstNodeCenter, this.diagram1);
                   bool allowModify = this.diagram1.Interaction.IsAllowed(firstNodeCenter);
       private void diagramView1_PreviewKeyDown(object sender, PreviewKeyDownEventArgs e)
           if (this.diagram1.Selection.Nodes.Count > 0 &&
               (e.KeyCode == Keys.Right || e.KeyCode == Keys.Left || e.KeyCode == Keys.Up || e.KeyCode == Keys.Down))
               if (!arrowKeyDown)
                   Point newCursorPosition = this.diagramView1.PointToScreen(this.diagramView1.DocToClient(firstNode.GetCenter()));
                   Console.WriteLine("start interaction");
                   //SendMessage(this.diagramView1.Handle, (int)Msgs.WM_LBUTTONDOWN, 0, lParam);
                   this.diagram1.Interaction = new InteractionState(firstNode, 8, MindFusion.Diagramming.Action.Modify);
                   this.diagram1.Interaction.Start(firstNode.GetCenter(), diagram1);
                   this.keyUp = new List<Keys>();
                   this.keyDown = new List<Keys>();
               arrowKeyDown = true;
               e.IsInputKey = true;
               t.Stop();
       private uint MakeLong(int low, int high)
           return (uint)((high << 16) + low);
       private void diagramView1_KeyUp(object sender, KeyEventArgs e)
           this.keyUp.Add(e.KeyData);
               t.Start();
[/code]
This is all the code there is in the application.
Dexter
Reply #5 - Aug 24th, 2010 at 8:00am
Hi Dexter,
Set Behavior = DoNothing when calling interaction.Start and reset it to its original value after Complete / Cancel to make this work. For the next release we'll try to integrate keyboard handling into the Behavior class to have an official way of implementing such scenarios.
Dexter
Reply #6 - Aug 24th, 2010 at 9:06am
Hi Stoyan,
I see now that you have started to test the 5.4 beta version. Is the keyboard handling programmed to be included in 5.4 or it will be included in a future version. This has an impact whether or not to continue to implement the behavior my self.
Best regards,
Dexter
Reply #7 - Aug 24th, 2010 at 9:47am
Hi Dexter,
It won't make it for this release, but for 5.4.1 in a couple of months.
Dexter
Reply #8 - Aug 24th, 2010 at 10:06am
OK! Thank you
