Normal Topic Layered Layout and NodeDistance ? (Read 1494 times)
yrauma
Aug 23rd, 2010 at 3:57pm
Hello Stoyan,
Im trying to tweak my main Layout used to rearrange all my diagrams.
I have a big problem with the NodeDistance property of the LayeredLayout. It does not seems to make any difference whatever the number I put....
I need to put more space between my nodes... LayerDistance works but its not the one I need.
Do you have any idea why its not working ? or maybe any other property I could use ?
Amaury
Re: Layered Layout and NodeDistance ?
Reply #1 - Aug 23rd, 2010 at 6:16pm
Hi Amaury,
This distance is applied to the more dense layers in the graph. Their neighbors in adjacent sparse layers are centered above or below them to make links shorter as shown here:
If you need to use the same distance in all layers, you can loop over the nodes after arranging the diagram and adjust their Bounds horizontally, but the result will be uglier in most cases, e.g. something like this but on a larger scale:
Also if there are several unconnected subgraphs, the closest nodes in two adjacent subgraphs will be at Layout.Margins distance from each other instead of NodeDistance.
yrauma
Reply #2 - Aug 23rd, 2010 at 7:44pm
MARGIN !
that was the property I needed.
that does the job just fine.
Thanks a lot Stoyan
