Normal Topic Multi select with custom behavior (Read 3916 times)
rdwheeler
Aug 23rd, 2010 at 5:30pm
I have created my own BehaviorBase-derived class. I can't figure out how to let multi-selection via drag work (i.e., drag a box around nodes to select them) with my new class. What I need is when the user drags from an empty area, begin a multi-selection box. Similar to Behavior.DrawLinks
Re: Multi select with custom behavior
Reply #1 - Aug 23rd, 2010 at 6:21pm
return new InteractionState(Diagram.Selection, 8, Action.Create);
rdwheeler
Reply #2 - Aug 23rd, 2010 at 6:37pm
Thats it. Thanks Stoyan, I love your fast replies. So with htis code I can multi-select, but while doing so the cursor becomes CursorHint.Disallow. How can I get it to Pointer?
Reply #3 - Aug 23rd, 2010 at 7:09pm
It should be shown only if there are no items intersecting with the selection rectangle. Isn't that what you are seeing, or do you want it a pointer even then?
rdwheeler
Reply #4 - Aug 23rd, 2010 at 9:30pm
I see. Okay I like the behavior as it is. Thanks.
sledenev
Reply #5 - Feb 11th, 2011 at 12:33pm
Stoyo wrote on Aug 23rd, 2010 at 7:09pm:
I need behavior like this, i.e. I want to be able to draw selection rectangle but withot cursor to become CursorHint.Disallow. How can I do it? Thanks in advance.
Reply #6 - Feb 11th, 2011 at 1:53pm
You could change DisallowCursor to a pointer if you don't need the stop icon to show at all in any situation. Otherwise set OverrideCursor for the duration of selection.
