Normal Topic XML/binary additional data (Read 2391 times)
smarrocco
Aug 24th, 2010 at 5:38pm
Is there a method to add additional info to the date file during calendar.saveto() operations that can then be read back with calendar.loadfrom() ?
For example, I'd like my calendars to save/load their start & end dates ranges.
Re: XML/binary additional data
Reply #1 - Aug 24th, 2010 at 6:06pm
There's nothing built-in. For binary files you could use the SaveToStream(FileStream) method and append additional data to the end of the stream. For XML similarly use SaveToXml(XmlDocument) and add additional elements to the XML DOM.
