Normal Topic Couldn't get design-time license for ''MindFusion. (Read 7474 times)
xplicit
Aug 31st, 2010 at 8:29am
I'm trying to compile solution, which references Mindfusion.Diagramming on the build machine using MsBuild and recieving following error:
LC0004: Exception occurred creating type 'MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Version=5.0.2.29184, Culture=neutral, PublicKeyToken=21bf4734c13246ea' System.ComponentModel.LicenseException: Couldn't get design-time license for ''MindFusion.Diagramming.WinForms.DiagramView'' in licenses.licx(1, 0)
I tried to remove all lines from licenses.licx, which helps with other controls (DevExpress, Infragistics), but with MindFusion it did not resolve the problem. How can I fix this issue?
Re: Couldn't get design-time license for ''MindFus
Reply #1 - Aug 31st, 2010 at 8:49am
Export the following registry key from your development system and import it into the build system' registry.
HKEY_LOCAL_MACHINE\SOFTWARE\MindFusion\ComponentLicenses
xplicit
Reply #2 - Aug 31st, 2010 at 12:34pm
Thanks, that works for me!
