Normal Topic Alignment issue in Diagram (Read 1291 times)
venki5star
Aug 31st, 2010 at 12:27pm
1) I have set both the properties to "left", but still contents in diagram is centre aligned. But i want content to be left aligned.
HorizontalAlignment="Left" HorizontalContentAlignment="Left"
2) After i set the width & height of a Diagram, i can see only diagram size gets reduced. But contents inside the diagram is not get reduced, also contents are not centre aligned it still be there in its original position.
Castle Rider
Re: Alignment issue in Diagram
Reply #1 - Aug 31st, 2010 at 5:55pm
1) The diagram uses absolute positioning for its elements (similar to Canvas) and you can set their positions via the Bounds property of nodes or ControlPoints of links.
2) Set the diagram's ZoomFactor property to scale its content.
