Normal Topic How Make Tree With  Assistant ?(Like Exel Chart) (Read 1474 times)
mj_majid_f
Sep 6th, 2010 at 11:54am
hi
Can You Tell Me How Make Tree With Assistant Node?
Like Image Below :
Re: How Make Tree With  Assistant ?(Like Exel Char
Reply #1 - Sep 6th, 2010 at 12:42pm
To mark a node as assistant for a subsequent tree layout, set its MindFusion.Layout.TreeLayoutTraits.Assistant layout trait to one of the values of the MindFusion.Layout.AssistantType enumeration (other than None). For example, the following code marks a node as assistant:
node.LayoutTraits[MindFusion.Layout.TreeLayoutTraits.Assistant] =
      MindFusion.Layout.AssistantType.Normal;
The following code runs an assistant-enabled tree layout on a diagram:
TreeLayout l = new TreeLayout();
l.EnableAssistants = true;
l.LinkStyle = TreeLayoutLinkType.Cascading3;
l.Arrange(diagram1);
Let me know if this helps.
mj_majid_f
Reply #2 - Sep 7th, 2010 at 7:04am
hi
thanks meppy
this work for me
